i have use same title block on all sheet however when i print PDF some of the title block fonts prints in Bold and some are regular.
not sure why it is behaving like it eventhough it is all same and no change. can you please advise how i can fix this.
thanks,
Mitesh
Font appears different on some sheet in title block
Re: Font appears different on some sheet in title block
For all support requests, please:
- Indicate the operating system you are using and the version thereof (e.g. Windows 10 32bit, Windows 8.1 64bit, Ubuntu 14.2 64bit, macOS 10.12, etc.)
- Indicate the exact version of QCAD you are using (see Help > About or QCAD > About QCAD or indicate the name of the file you have downloaded and installed)
- Indicate the QCAD Edition you are using (QCAD Professional, QCAD Trial-Version, QCAD Community Edition)
- Attach original drawing files (DXF, DWG, ...) if appropriate
- Attach exported files (SVG, PNG, PDF, ...) if appropriate
- Include screenshots if appropriate
- If there is an error message, indicate the exact message or include a screenshot of the message
Please be as specific as possible in describing your problem, so we can help you efficiently, thanks.
Thanks.
Please find below detail requested.
Windows 7 64 BIt
QCAD Professional
Version:
3.21.3.0 (3.21.3)
No error message.
hope this helps for you to troubleshoot and advise.
Windows 7 64 BIt
QCAD Professional
Version:
3.21.3.0 (3.21.3)
No error message.
Please attach drawing file.
I cannot find any bold texts in either files you have sent by e-mail. You might want to load 13.dwg and change a text to bold to see what that would look like.
Did you try to print PDF from DWG ?
have you seen at PDF i have sent you in e mail ? from PDF you can observe what i have mention about bold text on PDF of sheet 13 where as text appears regular on sheet 12. if you like i will mark it up and send you again.
I cannot spot any bold texts. Perhaps the slightly different rendering is caused by a double-insertion of the title block on top of each other in 13.dwg?
