hatch pattern too dense. hatch pattern generation aborted
turtle
Post by turtle » Mon Apr 08, 2019 3:33 am
I tried to make a hatch in my drawing and now qcad is slowing down to a crawl and I am getting the following on my console:
Warning:  RHatchData::getPainterPaths: hatch pattern too dense. hatch pattern generation aborted (timeout set to  2000 )...
Changing to a solid fill fixes the issue.
File attached.
Thanks
HatchTooDense.dxf
(202.1 KiB) Downloaded 681 times
Comments based on Version: 3.26.2 unless otherwise noted.
Re: hatch pattern too dense. hatch pattern generation aborted
Post by andrew » Mon Apr 08, 2019 11:25 am
There's a timeout to make sure the display can be refreshed within a reasonable time frame. You can adjust this setting under:
Edit > Application Preferences > Graphics View > Appearance > Display and Performance > Timeout for hatch rendering
turtle
Post by turtle » Mon Apr 08, 2019 4:03 pm
Thanks for the quick reply!
Is there a way I can change the hatch in that drawing at that scale so it does not slow down Qcad?
Post by andrew » Mon Apr 08, 2019 5:23 pm
1. Select > Select All
2. View > Property Editor
3. Change "Selection:" to "Hatch (7)"
4. Change property "Scale" from "0.00425" to "10"
You might have to do some cleaning up, since there are several hatches on top of each other.
turtle
Post by turtle » Tue Apr 09, 2019 6:28 pm
Thank you, I find it really helps to have the printed copy of your book, but I am still going to have lots of questions on here. :mrgreen:
I see now my 7 attempts were successful just at the wrong scale ;)
I never thought it would let me put a hatch on a hatch.
I take it the best way to clean it up to
Rectangle select that area, and click detect duplicates, then click the eraser ?
Thanks!
