Viewports professional only?
ZIMSKY
Post by ZIMSKY » Sat May 04, 2019 5:04 pm
Getting conflicting info here... but on the features page here https://qcad.org/en/qcad-documentation/qcad-features viewports are listed as being in the free version, but I don't seem to able to use them.
Re: Viewports professional only?
Post by Husky » Sat May 04, 2019 6:18 pm
I assume you are asking for the advanced concept in QCAD to print drawings by creating a layout. Correct? If so, yes that is only available in the Professional Version.
The "Viewport" which is also available in the CE Version is a setting to divide the Model_Space in multiple views. That has nothing to do with printing.
