No 3D CAM preview menu item
davorin
Post by davorin » Fri Jan 26, 2024 11:13 am
Good morning
Just downloaded QCAD/CAM 3.29.3 for Apple Silicon.
Doing a simple path for milling I can generate the path, but there is no 3D preview menu item visible under the CAM menu.
Furthermore the generated path looks kinda odd when I choose to mill inside the path, that's why I wanted to see the path in 3d.
Bildschirmfoto 2024-01-26 um 11.11.16.png (63.12 KiB) Viewed 58479 times
Re: No 3D CAM preview menu item
Post by CVH » Fri Jan 26, 2024 4:29 pm
The odd looking inside path is probably the result of radius compensation and lead in/out.
Possible even with G41/G42 and 'Overcut'.
As presented it will indeed ruin the lower left inner corner. :wink:
Is it an error? Not necessarily, it is the mathematical approach of the chosen settings.
It is practically impossible to have a smooth lead in/out in hard inner corners.
The best solution is to start somewhere in the middle of a side of the triangle.
Experiment with a polyline and a startpoint somewhere on a side, with different or even no lead in/out.
It might that it is not even possible with G41/G42.
All depends on what is required.
Post by andrew » Fri Jan 26, 2024 4:43 pm
Unfortunately, we haven't yet succeeded in porting the 3D preview to the M1/M2/M3 architecture. This will likely be added in a future release for that platform.
About the starting point, please refer to our tutorial at:
https://www.qcad.org/en/tutorial-qcad-cam
Return to “QCAD/CAM”
